I've just bought my 2nd Renault and I'm having problems fastening the middle rear seatbelt. Previously in my old Clio, I could clip all 3 seatbelts with no problems. My new megane is a nightmare! The 2 holders (where you clip them into) are infront of each other rather than back to back and there doesn't seem to be enough space. Any advice or other people with the same problem? Apart from that, I love my car!
HI there and welcome.
You could obtain seatbelt extenders, which can be clipped into the receivers in the seat, thus giving more space to clip the seatbelts into them.
A google search will display many results.
HTH,
Paul
  • Like
Reactions: coup
Aside from the extenders^
Yeh the rear connect is a bit tight , especially on the coupe where there is less wiggle room..
You can lift the rear cushion to adjust the separation slightly or :
Especially if your rear passengers are "bigger than the average bear", get the middle and one side passenger in first and belted up then get the 3rd rear seat passenger in :(
