A couple of months ago I noticed that the air con on my 2007 Megane was not blowing cold air. I booked it in at my local Renault specialist to have the air con system fully serviced. They drained, regassed and checked the tightness of the air con and reportedly found no leaks.
At first all was well and ice cold air was coming from the vents when the air con was switched on. I turned the air con on today and noticed the air was not ice cold as it should be.
Normally when you press the air con switch you can here the compressor kick in but now it won't. Is this due to lack of pressure?
Any ideas as to whats causing this?
