evening all i am new to this site i have just bought a megane coupe 2000 x plate 1.6 sport i have just drove the car home and it is almost stalling at traffic lights and seems to hold back when i accelerate wawy from lights roundabouts ect i have looked under the bonnet ant the hose to the air filter has 2 large rips in it it was notlike that last week when i veiwed the car i will take this up with the garage tommorrow by replacing this hose will this solve the problem?the car seemed to drive fine last week on test drive before i bought the car could they also be a problem with the icv i have got bits of info off the net but cant find a true answer many thanks for your help
RIP 31-12-2008
Hi there and welcome to Renault Forums hopefully one of our more learned members will give you advice soon,
Regards Leroy
Stalling at traffic could be caused by many things - to start from fuel, fuel pump malfunction, fuel filter clogged, faulty TDC sensor, faulty MAP or Lambda sensor, faulty coils, or spark plugs.
Give it a service first - change fuel and air filters, and if the problem persists, change the spark plugs. If still no solution to the problem - have the computer checked for any faults - if the problem is from a sensor it will show up and indicate which one will need to be replaced.
