Roof was working fine, few weeks later went to drop the roof and nothing is happening.
Switch moved to roof down position and but nothing happening, no beeps, no warning messages just nothing at all.
I have checked the fuse the roof shares with the horn and it's ok, also checked the 40amp large side mounted fuse also OK.
Yes, the boot cover is in position and the microswitch is working OK....but this would usually give a roof error message?
I've cleaned the switch wiring connections and no change.
I'm at a real loss here, any ideas guys?
Discussion Starter #2
I should add that the windows do not go down either when the 'roof down' switch is enabled.....but they do go down on the window switch so no issues there.
Question:- I'm wondering if the UCH has control over the roof?
Question:- I see roof control modules for sale but can't find where they are located?
Does anyone know what the ECU does on the pump....
...in fact can anyone throw some light on the roof opening sequence...?
Cheers guys
