I have a 2006 Megane CC 2 litre petrol (pre face lift) which i have had for 4 months, i notice it is very jerky on the gear change and often falters on pull away, the engine seems to hold high revs when changing gear before dropping, i have tried different fuels but no difference, so i assume the mapping is not right, has anybody else come across this problem before i am told it's a characteristic of the car!
i have got used to it by slipping the clutch etc, but dont see this a long term solution,
ideas welcome....
also have renault come up with a solution for grinding front brakes and screaching rears, i was told by dealer they were working on it!
Hello & Welcome to the Forums Rmperry.
Hopefully someone with a more technical background will be able to advise you further on your post.
Ottoman
