hello again,
could anyone tell me how to remove the passengers door card from my 2003 megane.
any help would be great
cheers
Paul.
Hi mate why do you need it off
why iam asking is that the door panel flaps open the bit where you rest you arm all that opens up iam going to have a quick look how to do it and get back to you ive done it before to remove my windows for tinting
steve
hi mate,
want to remove the whole door card so i can have a look at this window regulator and to see if it is a diy job for me or a renault job. Also is it possible to wind the window back up manually so i can at least get the window shut to keep out the rain?
many thanks
paul.
Find an ANswer ?
Same problem. 2003 Megane DCI. Passenger front window packed up, told renault unit will be circa £260 .... got a replacement off ebay but cannot get the door card off. 2 screws behind door pull, i behined door release, 2 bolts bottom of card, i behind upper section (once released and hinged up), speaker grill removed and all screws bar speaker retainers slackened off. Cannot bet this card of ... any assistance greatly appreciated.
