1 - 9 of 9 Posts
Hello,
Just collected my 66 plate Megane Dynamique nav. When the headlights are on the clocks dim too much. I can't work out where the dimmer control is.
Looked in the settings and around the dash. There's nothing that stands out.
Please help
Thank you
should be under the fan vent on the driver’s side of the cockpit, there should be a rheostat for headlamp levelling and a rheostat for dashboard lighting control, on the panel the starts to turn underneath towards the pedals
Grand Scenic 1.6 2007
.......and outboard of the two wheels there may be a rocker switch for the child locks if you have rear doors.
Tartan terrorist in a dress..
Did you not get handbook with the car ? If not you can download one from Renault uk website
From the main menu, press 'System'
select 'Display'
This menu is used to adjust the following settings:
Day brightness adjustment
Night brightness adjustment
Switch to night mode at night: Tick this option to activate the automatic switchover to night/day mode. The system switches to night mode when the external light is low or when the headlights are lit.
Use night mode: Select this option to force night mode.
select 'Display'
Surely this info should be in the drivers hand book ? (the one in the glove box that no one reads!).:grin2:
1 - 9 of 9 Posts
