Hi, Was wonering if anyone can help. I have a 04 reg Megane 14 Dynamique which I have owned for a coupke of months. Everything was working fine until last week when the passenger electric window just stopped working for no reason. When i press the switch down i can hear a faint click, but nothing happens. Anyone have any ideas on whats wrong, i'd rather not take it to a dealer and fix it myself it possibe. Thanks in advance
Matt
if it is just one window then you can rule out the fuse, its either gonna be the switch, wiring or the motor. If you press the switch and you hear a click, is it from the switch or a electrical relay, if it is a relay then it looks like the switch is ok.
check the wiring between the door and the car if you can-most wires get damaged there, if no joy ,your gonna have to remove the door card and do a voltage check at the motor and operate the switch
good luck
