Hi all,
My heater fan is clicking (catching) quite badly. Is there a way of checking / getting access to remove whatever's catching?
I know how to access the cabin filter, can I check from there?
Also my engine temp guage is only getting to about 2mm below the normal running temp. Engine runs fine but mpg seems quite disappointing.
Could it be the sensor on it's way out?
Thanks in advance,
Andy
Hi all,
Thanks in advance,
Andy
I have a similar issue where temp gauge goes up and down between normal and a couple of mm below and also my fuel consumption up...... if you find a solution i would be interested to know what is causing it
Sorry to hear you're having problems too...
Let's hope somebody replies to help us out! :d
