I've spent some time searching through here and google to find a resolution to my issue but havn't found anything yet.
The problem is that the radio won't turn on. It was working fine. Took the car to the car wash. Went through it fine then got out to re attach the ariel and then pressed the on button and then nothing :(
Rang the dealer and they said they would have a look it it. The problem is that I am planning a driving trip to Ireland leaving on Thursday and they can't fit me in before then. I was wondering if there is a fix or else I will be doing a lot of driving without a radio :(
Any help would be appreciated :) thanks
MK3 Scenic Dynamique 1.9 Dci 2010
Not sure how you edit posts on this forum. But i forgot to add that it is not the fuse as I have already checked
Try pressing the start button without pressing the brake/clutch pedal then switch on the radio manually
see if that works unless you have already tried this?
