Hi guys
Been having a problem with an int airbag warning light on my 1.6 megane II 2002 plate. Seems to come on at the same time as a solenoid clunking in at the same time. Doors seem ok when stopped or on the move but the steering isn't locking on exit. This message is displayed on the display too.
Is this a regular thing as I've seen a couple of messages from owners with a similar problem.
welcome to the forum macca.
on the laguna there is a switch to turn the airbags off on the dash on the passenger side.with the ignition on turn the switch off for a few secs then turn it on again,it may reset the sensor.also check under the drivers seat that all connections are intact.
good luck.
S
Check the passenger side too. Faulty connections under *either* seat can cause the light to come on...
