Not quite sure how they came to the conclusion that the ARB bushes are ok, when the bolt on one of them is 3/4 undone, this would make this bush behave as if it where worn as it is not locked in place now strange conclusion! CV joint, I would be doubtful myself as you say they mainly play up on lock, if you can hear this joint in a straight line then it will be deafing on a bend. Wheel bearings are another noise not usually a knock though more of a hum/drone in a straight line and are silent on a bend depending on which side (sometimes) not sure on top strut mount never heard one to make a comment, our ARBs knocked no matter what the throttle was doing, heard loudest whilst cruising towards the end, would start to go when car got to around 25mph by the time it was at 30mph not a sound, I think it was silent on bends as well but would come back once on a straight line again (passed its MOT with em like tihs) you obviously have them now so I would change em, as for the bolt hack saw it off and replace it with another 31mm nut/bolt , did you wire brush and spray lube before you tried to get it off, ours didn't look knackerd, was not a lot of play in the bar, but once changed knocking has now gone, have you tried bottom ball joints? they can knock as well, as they play free, you will need a bar to check them ans car on a jack wheel off floor, bar inbetween bottom arm and wheel bearing carrier (knuckle) and try and seperate them (up n down movement), there should be NO movement between them, if there is; ball joint is knackerd, again simple to replace, two 13mm nut/bolts that hold it to bottom arm, and a 14mm (I think) pinch bolt holds it to knuckle. no need to remove strut, no need to remove bottom arm, very easy to do, again did the wife 2 years ago (spilt boots on them), the wifes CV joints use to knock but only when accelerating out of a bend or junction, not in a straight line, boots had poped off and joints ran dry, usual Renault fault, I am guessing you have checked all the nut n bolts on the suspension arm and struts to make sure nothing is lose, wheel nuts tight etc. suprising how many people run around with loose wheel nuts, bring car in for knocking sound, and we find them loose, only has to be a quater of a turn and th erim will move a little, which losens off the rest result - knocking at low speed, just another thought popped into head has it aftermarket alloys on or stock Renault alloys, if after market ones make sure it has its spigot rings in, no rings will make the wheel move on the hub, I bought OZ wheels for the wifes Coupe 5 years back and it knocked and steering vibrated every now and then, turns out after hours of checks the shop that fitted the wheels had forgotten to put the spigot rings in, once they did this knocking and vibration gone! slly bit of information but it might be the key!
