Lost Reverse lights. Checked cabin and under bonnet fuses and reverse light switch. All checked good.
Wire traced 12vdc with ignition on, gear in reverse, a needle to pinch into the light bulb relevant wire attached to a multimeter and ground.
Found Open Wire inside the connecting link, wire protect rubber boot, of the hatch to the left hand side of the luggage compartment.
