Hi everyone
I've seen it mentioned all over the forum and I've searched and searched and browsed and browsed and searched again - but I really can't find the guide for removing Megane Mk3 front door panels! Any tips?
I need to get in to investigate which custom speakers I can mount. Thank you in advance!!
Tartan terrorist in a dress..
Try this ..should be more on you tube
Thank you for the link. It looks a bit reckless but get's the job done :) I thought there was a written guide with photos in here somewhere but I'll give this a go tonight.
This one is for the window regulator but if you watch when he latches the glass to the regulator, you should get the idea....pop those latches and then lift the glass, usually rotate it to get it out of the runners and door.
