1 - 1 of 1 Posts
Hi, i have some problems with my megane, 2007 1.6 16v. My speedometer stopped working, i have abs, handbrake, serv. key, check engine lights on. I went to an electrician and aparently his can-clip can't connect to any module on the car, it barely got the VIN code. He disconected the abs module and the clip immediately connected to the car(except abs obv.)... . I went and borowed an sh abs module and pluged it in....same thing...can-clip disconnected from all the car systems. All fuses seem ok, the battery is ok, the alternator is ok....what should i look after?
The electrician said it probably is a torn wire somewhere and basically has to dismantle half the car to find and fix it witch will cost more money than the car is worth.....
1 - 1 of 1 Posts
