I have a 2002 Megane Classic 1.4 16v. Idles rough and no engine power, it does start, but when I check which coil is faulty found 2&3 not working. Already put new plugs and coils but still no spark on cyls 2&3. I even tried coils 1&4 swapped with 2&3 and still no spark on 2&3.
Already checked the wiring from connectors to power box and ecu and seemed fine.
Found some schematics on the web for the ecu and still have to check if there is voltage from ignition switch to the coils.
Could it be the TDC sensor? only for 2 cylinders?
