Hello, I have a 1998 megane 16.e rt.
In low revs, i Have a rattling coming from ym engine... i think, mainly bad in low revs, similar to a grinding noise... no idea what it is...
if anyone has any info, please I would be happy :)
does it have a plastic engine cover?
Had similar thing on my 06 1.9 DCI recently. Just pushed it back on to its clips. If its not that check the obvious cables and pipes etc in case they've worked loose.
Stick your head under the bonnet with the engine running, maybe try to stress it a bit at low revs with an assistant by riding the clutch lightly in reverse. might help you locate the rattle.
Hope thats useful
