Had an issue earlier (see other thread) and as a result lost most electrics! When I sorted it the radio had obviously lost its code, I have been given a code online, but it does not work. I have also downloaded a code calculator, and used that, and got the same code. The porblem is when I input it after putting in the last digit and pressing either '6' or the button on the radio control stalk, it beeps and says 'error' and I then have to wait for a reset. Does this mean that either the radio has had it, or that the code has somehow been changed??
if code is not accepted it means it's the wrong code. go to your dealer and get them to get it. it'll be on renaults system, maybe the radio has previously been changed..
