Hi, can anyone help.
Got a second-hand 2001 scenic off a friend. Took it out yesterday and pressed button to bring window down but now Driver's window is refusing to come back up. There's still a whirring motor sound when you press the button, but no show of the glass.
Have read previous advice about removing fuses for newer scenics, causing the window to go up - but I've no idea which is the right fuse. There's four 25amp white fuses labelled as 'windows'. Any idea which is the right one, or whether this is the right solution for a 2001 scenic where the motor's still whirring?
Should I just take it to garage!?
Please help - I'm very clueless!
