Hi there got a prob with my 97 Megane the speedo is either all over the place or dead and the mileage is not clocking properly but the rev counter is fine.
I took the car to the renault garage and they changed the speed sensor but did not fix the prob they reckon i need to change the whole dash at cost of over £400 just wonderin if ne one else has had this prob and if this fixed it.
Cheers for your help in advance
Rich
hi m8:)that sounds about right Ive had this a few times over the years, and its all been meganes, quite common. new set of clocks required.
good luck with it and hope this has helped :)
speedo
has your megane got on board computer button on end of wiper switch press button switch ignition on all gauges should work if they do speedo head is ok found that multi plug beside battery is bad for corroding wires it is on left side of battery hope this helps cheers kellykars.
