Hi All,
I have a 2008 Megane VVT auto hatchback that has done 14600 miles from new. When starting first thing in the morning it gets to third gear then makes a thump and displays check gearbox on the dashboard and will not go into 4th gear.
If you stop the car and restart it it works initially but then comes back again, this can happen between 4-6 times until it has warmed up then everything is fine. The garage (not main dealer) have checked it on their computer and have said the ECU shows no error code so are stumped as to what it may be. I am concerned that I may cause damage if I continue driving it can anyone give a pointer as to what the problem is please?
Thanks - Steve
Thanks - Steve
