85 R11TS, 85 R9TXE, 97 Extra 1,9D, 97 Megane 2.0 RXE, 02 Clio 1,2 16V
I'm looking at a 97 megane 1 1.6 8valve with a K7M A 7702 at the moment, the car had the clutch replaced, apparently the mechanic did not disconnect the battery when taking out the g/box.
After the clutch was replaced the car no longer starts.
Renault apparently says that the ecu is fried, something about one of the pins giving only 8volt instead of 12v.
From what i can see the car does not have a factory fitted immobiliser, no IR reciever in the roof.
The battery was flat and I didnt have a jump kit with me to do the normal checks, the car has been standing a while.
Question1: Could it have a RF immobiliser?
2:Is there any way to test the ecu without fancy equipment?
3:Can the ecu be fixed DIY?
4:Apart from earth problems can anyone suggest any checks?
Thanks in advance, any help is appreciated.
