1 - 13 of 13 Posts
got a renault megane coupe 1.4 16valve and has a misfire changed plugs and a couple of coils took it to renault they said its the cat of all things, anybody got ideas feedback would be appreciated.
_woo
its not got a distributor just 4 coils (one per plug) which goes directly onto the plug, the misfire happens about 2700revs.
Ok then, what I would do is check for any leaks on the intake side of things, check vacuum pipes for leaks also as that would cause misfire and poor idle. If you can't find any visible problems with the hoses and pipes then I would look at the fuel pressure regulator or fuel pump as there might not be sufficient fuel pressure entering the engine. Also your injectors might be cacked up or faulty. So many things but if you start with the easiest then you might catch it before you have to spend any more money. Hope this helps:d
Discussion Starter #10
al try a tdc sensor to then its trial and error at moment had a diagnostic done it said ignition failures danger of overheating whatever that means
Hi Peter, it might be worth replacing the other coil packs just to eliminate that side of the ignition fault you're getting from the diagnostics. Also is your car overheating? Maybe the temp sensor is giving the ECU dodgy readings and screwing up the fueling?
1 - 13 of 13 Posts
