1 - 10 of 10 Posts
Brought my auto x reg clio 3 months ago and just been told that i need a new instrument panel as some sod has previously taken mine off and buggered about behind it to hide an ABS fault. Would an instrument cluster of a manual fit on an auto?
Hi , sorry no it will not , you will need to replace like for like , on the back of the unit should be a renault number 10 digets long i.e. 8200****** or 7700****** or the like , have a look on e-bay see if you can match it up , Rich
thanks for that, been on ebay and there are 3 that have come from same make and model as mine but they all come from manauls :( guess that'll teach me for not be able to drive a manual
Hi , if you post your vin i can give you the renault part number and price , Rich
VF1CB0L0A23514549
Cheers, i've got a quote from renault to supply and fit it but i was looking on ebay i the hope that i could get one cheaper and save a bit of money (as i also have to do alot of other work)
Unit price excl. VAT 282.67 GBP Unite price (with VAT) 339.20 GBP
77 11 368 921​
part number
This is the service exhange price
these are all the old part numbers , all units with any of these numbers will also fit , if you can find one in a scrapy or ebay , Rich
7711368921
7700428501
8200054412
7700428715
7711368921 7711368921
8200054412
Renault will supply and for for £389 (probably coz they've already charged me £900 for other work) but thank you anyway - not been on a forum before so this has been really helpful
Couldnt you get it repaired. Lots of electronics places use a postal service. Check out adverts in "car mechanics" or "Autotrader". Got to be worth a try;)
Scenic mk1ph2, RX4, ID35s11
hi
ive just hacked up a auto lag II dash pcb, what did he do to yours???
its all surface mount chips n bits on the side facing you under the dials, nothing really major in way of soldering, so should be easy fix to replace an ABS amber smd led and pull down reisisters.
much cheaper than a new reprogrammed one for just 1 light thats out...
1 - 10 of 10 Posts
