hi just looking for a bit of help please,
last year i was given some front brake callipers from a mk1 clio 1.8 16v im now thinking of fitting them does anyone know if they are a direct fit or what i will need to buy/do to make them fit i have a 96/97 mk1 clio 1.4rt
any advice is greatly apreciated,
thanks
Stuart
It should fit, of course along with the vented discs from 16v. As they are a bit larger than original check the clearance between the caliper and the wheel as 13" wheel might be too small, 14" maybe just , 15" for sure.
The vented discs and calipers off of R5 GTE, R5 GT Turbo, R19 TXE or Megane 1.6 on the other hand have the same diameter as standard clio ones and also go along with 13" wheels.
DG
