My son has just brought a MK1 clio for his first car. we've checked all the fluid levels but can't see the screenwash reservoir anywhere. Can somebody please point us in the right direction as the were no manuals with the car.
Lift bonnet, and it's under the scuttle cover (windscreen base) one side holds the jack the other is the washer fluid, hth, on the side with the jack , it be in you best interest to remove the jack and have a clean out of any debris, this is because the ecu lives here and any debris can hold water and may cause some problems later on.
