Hi people, my girlfriends Mk1 megane '98' front speakers have just gone and needs replacing. Just wondered what size i need to get and how hard is it to get access to the front door for replacement.Any help would be great
Sorry no one has helped thus far Another member asked the same question the other day and I think the reply was that most Renault front speakers are 5.25"! Easiest way would be to remove the door card and check yourself to make sure. Door cards are normally held on with a succession of screws and clips, you'll need to find all the screws first and remove certain bits of door trim which should then enable you to pull the door card up and away from the door
