Driving my MK3 Clio the other night and the clutch pedal went rock hard when changing gear...
The clutch is now permanently engaged and I had the fun task or driving the vehicle home 15 miles with no clutch!
Looking underneath the car there does appear to be a fluid leak around the back of the gearbox near to the slave cylinder hose. The master cylinder looks to be ok although I did damage the nylon ball joint trying to disengage the clutch...!
The clutch was disengaging fine prior to this - it just happened!! I have ordered a new slave cylinder but I'm starting to think this may be related to the pressure plate or maybe even the clutch disk too as there is a loud squeaking sound coming from the front of the car.
Has anybody else faced this issue and what measures did you take to fix this? I suppose the correct way to properly diagnose this is going to be to take out the gearbox and inspect the parts...
