Hi all,
Been here for a while, looking around and i finally have a questions.
I have bought some mk3 clio tail lights for my mk2, but uppon fitting them, the light configuration is wrong,
For instance, what should be the reversing light is the fog light and what should be the indicator is the reversing light.
So my question is, is there another plug i can buy to change the wires around or is there a light unit i can buy to fit these tails?
Thanks...Anthony
Presumably you mean later Mk2 lights on an earlier Mk2. The Clio Mk3 is completely different.
There is a diagram on the forum I saw a few days ago that shows how they need to be rewired as the wire colours are different between the two. You simply cut the connectors off and re-solder them. The info is all here somewhere...
