I need to fit a Nokia CR 23 cradle. it comes with a mounting that needs screwing into the trim. I don't want to make holes in my car if I can help it so does anyone know of a specific mount for the laguna II?
I have used sticky pads for now but I don't expect them to last long!
There are loads available. Do a Google search for 'no holes phone bracket'
When I had the Lag 11 the bracket fitted at the side of the Air Con display.
Hi pw1962, the big two are Dashmount or Brodit ....
Dashmount are metal and Brodit are plastic, both cost about the same £25'ish but you'll get dashmount much cheaper on e-Bay
Check these out
Dashmount brackets: dashboard mounts for mobile phone car kits
or
Brodit.se
Personally I'd go for a dashmount ... double check the fitting as they vary with model and phase.
Hope it helps :)
