after disconecting wiring from window motor to diagnose fault on window regulator wiring reconected but when pushing up or down switch window only moves about 50mm and stops.after releasing switch and then pushing it again window moves 50mm again.after replacing regulator due to cracked clip fault remains.it requires up or down switch to be pushed and released about 8 times to fully open or shut window.any ideas apreciated
