hi,i think that i need to replace the indicator/dipped light,headlight stalk on my 2005 modus.the full beam wont come on nor do they flash.what i need to know is,do i have to remove the steering wheel and if so can you please help and let me know how thewheel is removed in relation to the airbag etc thanks
There no need to remove the steering wheel it just clips out to the side but there is wire on the underside that plugs into the wiper switch remember to unplug this first or it will pull the wires out
Lexie_2005, did you successfully fix this problem? I ask as I appear to have the same fault developing on my 55 plate modus.
P
My wife's Modus had a problem with the dipped beams coming on with the indicators
It turned out to be a broken wire in the connector mentioned above....It might be worth a look before you start replacing parts :)
