Modus wiring diagram
2 reading
2.9K views 7 replies 2 participants last post by  ours2012
#1 ·
Does anyone own a modus wiring diagram?
Simon
#6 ·
what year is this modus?
you have disconnected, and reconnected the car battery
(asking here, as you have started this thread and dont wont to go and Try and find your other thread ), does the locking system from the switch inside work,
IF no ,
There is another fuse box behind glove box area, and as you look at it, the fuse closest to the steering wheel or drivers side of the car, is for central locking
#7 ·
Had the battery tested, made sure all the connections were good on it. Glove box removed and took out the BCM and had a look at it (in case there was water ingress or shorting I could see) plugs to BCM cleaned with contact cleaner. Checked second fuse box fuses and relays. Everything fine
central locking works fine from button on dash, it’s just the remotes. They both stopped working the same day, have changed batteries in both but still nothing.
car starts and runs perfectly, everything else works on the car.
#8 ·
There is another fusebox behind it,
Have switched other laptop off, and need to get in the bath , so wont switch it back on until tomorrow.
REPLY to this thread tomorrow, ( IF you reply tonight, and I'm not thinking, and just read it, it wont show up again tomorrow for me ))
Will find out exactly where it is, and how to get to it
