Just a thought here, but could it simply be that the power lead has loosened & disconnected, or that a fuse may have blown?
Both would explain the symptoms you are experiencing, which I feel must be related and share the same reason.
Welcome to the forums, by the way.
Paul
thanks for that but this is the second time since i have had this car that it has happened.the fuse is fine and the connection is fine.the first time i removed the leads then replaced them.the code message appeared and i entered it and it worked.this time i have power but no message so frustrating for a 2007 new megane this surely should not happen or is it a common fault for these cars.
