My clio 1.4 has intermittent problem with starting. It turns over but just wont start
I had all the spark plug leads replaced a year or two ago
any ideas?
I have a 2001 51 plate 1.2 Clio 16v and have got problems with it starting. The dashboard warining light that shows a coil underneath a box with a zig zag in it does not go out and the car does not start. Sometimes the light goes out and it then starts and drives ok but over the last couple of days most of the time when this light goes out it still will not start. I have today changed the crank sensor (tdc sensor) for a new "Fuel Parts" one that I bought but the cars symptoms are still the same. The Immobiliser light goes out ok and the car turns but will not fire. I would appreciate any help out there. Thank you.
