my lil baby, its going in the bodyshop at the end of the month so will all be changing but let me know wat u reckon so far
Hi James,
What sort of work is involved fitting the headrest screens as an after market option.
Ottoman
my sponsor done it for me but from what he told me its a lot as its packed with expanding foam, which you have to repack, they also aint that deep as you probably know and then you have to drill the hole slightly wider at the bottom of the headrest, poles luckily there is a hole running all the way up so its fairly easy, then run the cables down through those poles through the back of the seat and then into the wiring which you can place all in the bottom wiring holder under each seat
