ok i found a old Renault 5 gtl (pre 85) siting by a guy i know's house anyway it has been siting for a long time and i started to look at it because i had no idea what it was after seeing that it was still a solid car with little rust i figured it should be saved and would make a cool project
now the ideas i had so far are lower it a bit ,see if the 3 bolt rims can be changed to something else like a 4x100 hub set up
maybe add a set of diffrent bumpers or something and shave some things like trunk lock to clean up the looks of it
i do not know anything about the motors in Renault cars are they reliable, is there any aftermarket for these motors or is everything got to be custom
i want to kind make a sleeper out of it being such a small car it should respond well to more power as it is so light if i cant make any power with the motor in it i was thinking of pulling it and storing it and putting a turbo diesel vw motor or a vtec Honda motor like a b18c in it
don't know how you will take this project as i can not find any of these cars that are done up but i will read all your comments
