N
i dont no what to do my tempreture needle keeps moving up n down then staying at the bottom for about 20 seconds its been happening for about 3 days i went and brought a tempreture switch but does any 1 havea clue as to what this could be and any advise on what to do ?:confused:
but 1 good thing it never goes above the middle line
The temp switch is usually around the thermostat housing - remeber you are likely to loose engine coolant when you remove it.:)
N
hi thanks for that it seems the problem has been sorted i had the tempreture switch changed and the thermostat and fingers crossed it st\ays ok thanks for you help
