recently bought a clio versailles 1995 model and i found out the windscreen washer does not work. it may be that the fuse has gone as the tubings are not leaking. can anyone tell me where the fuse is for the windscreen washer? thank you
where arew they situated....i left the handbook at my workplace and want to fix this problem soon?
thanks
yep it was low i filled that up and it didnt work so came to the conclusion it was the fuses
Well done anil - you just found the secondary fuse box which is beside the washer bottle and the other is under the dash - the lids of both should have a diagram showing which fuse is which.:rolleyes:
