1 - 1 of 1 Posts
Hi I hope someone can help I recently changed my alternator because although the old one was working it was only running on 13.2 volts which wasnt sufficient enough to charge my battery anyway purchased a new one and got it installed by a friend of mine who is a mechanic now heres the strange part the alternator is working fine however I'm now getting a alternator charging fault with a stop sign on dash the light goes out if the voltage remains below 13.8 volts as soon as it creeps up to 13.9/14.2 max output the warning lights stays on and wont go out I've checked all wires they all seem fine the car drives ok starts and stops as it should lights air con heating all work fine the light wasnt on before I changed the alternator
1 - 1 of 1 Posts
