1 - 8 of 8 Posts
Hey,
Got a '07' Clio Extreme and have not got back speakers. ive checked my manual and ther is no sign of the size or what fits into them, There is a connecter already wired. just need to fit one in.
Does anyone know what the sizes are?
Much appreciated
Speaker Size
hi the speaker size you are looking 4 is 130mm a i have just put them in my clio 138 dynamique s dead easy to fit as screws are there, only probelm you will need a torque screw driver as the screw heads are not standard philips ones hope this helps and the sound quality improves alot.
cherrs nips
yes they look fine but you will have too break off two lugs to fit as the door recess is designed 4 just two screws but they will break off easily with a set of pliers i had to do this with mine also remove the speaker grill in the back and you will see what i mean .
hope this helps
Exellent Help Nips
Thanks Very Much, i will purchase them, and just have to see when i get them. All the plugs are standard to fit into the speakers cause there is a connecter already i behind my speaker grill
had to take off renault connection becauseit wouldnt fit the speakers i bought, but i joined the speaker wire to the cable that came with speakers with the right speaker connection. but you might be lucky as i bought kenwood speakers . hope u enloy your new sound
I may have a set of the standard ones lying around as I upgraded. Not bad speakers considering I changed from the standard 11 watt ones to 250 watt speakers with and upgraded headunit and never found much improvement:confused:
1 - 8 of 8 Posts
