I have a Renault Laguna 2.2 TD, P Reg.
However I had the engine changed and as a result it now has just a standard 2.2 Diesel engine.
As I need a new clutch, which one do I buy?
Have you still got the original gearbox fitted?
I doubt very much that the clutches are different,but it would be worth seeing a decent motor factor and see if there are different part numbers and if there are,what the main difference in the clutches is.The splines on the gearbox shaft and the size and shape of the flywheel are the two factors to look at,but I would strongly suspect the clutches are the same.The turbo one could have stronger springs in it to cope with the extra power,but I'm not 100% sure about that......
