1 - 9 of 9 Posts
Hi people, great site... just brought the wife a megane scenic and it has a slight fault. on tickover the oil and temp light flicker and as soon as you rev it they go out. any ideas what this is please?
thanks in advance
When you turn your ignition on there should be a row of 0000000 before the mileage appears this tells you your oil level (all 0`s good 0_ _ _ _ _ bad this is the lazy way dipstick is best).
thanks for all your replies, yes i do get the 00000000 with ignition on, levels are fine. if you gently touch throttle they disapear. they seem to flicker quite faint.
Tourerman
When was the oil last changed and what grade of oil is in the engine, could be too thin or wrong type?
If oil is OK could be oil pump or oil pressure sender on it's way out.
thanks, but its the water temp light and oil light at the same time, temp gauge is fine, alternator is ok.... a strange fault.:confused:
1 - 9 of 9 Posts
