:d hi to renault forum,
My name is rob This Saturday I will be buying a white 98 rt 1.6 scenic, body work needs a little TLC but I would like make it stand out from crowd, is it possible to change anything on a scenic Mk1 ie lights, bodywork, wheels ect.
I will start posting pictures and document my progress.
cheers rob:cool:
lower the scenic
:confused: hi again, have been searching around a few websites looking for parts to customize the Scenic which i found alot , would like to know what is the biggest alloy wheels that fit on the scenic and can you lower the scenic have found lowering kits from PI springs 30mm ?
Hi and welcome to the forum i look forward to the pics sound interesting good luck Donald.
Wheel size with 30mm springs i would not tend to go past 17" i hope this helps.
