1 - 9 of 9 Posts
Today in the family's list of cars to fix, was MIL Nissan Note 1.4 - boot lock switch not working as wiring loom rubbed through in roof, located fault and repaired and a oil change thrown in for good measure - was fun as all wires are yellow!!
The tension builds as our hero attempts to defuse the bomb.
Only 30 seconds left on the timer....29...28.....
Should he cut the yellow wire or the yellow wire..... hmmmm, doesn't quite work :grin2:
you should have a look at a Lynx helicopter wiring loom, every single wire is the same gauge and same coloured white insulation, with some yellow ones, and there is a total of 7 miles of wire in there - fun fun fun
good job I just flew them and not fixed them
Them yellow ones will be for the boot lock :nerd:
Westland started off as a garage door manufacturer then changed to helicopter manufacturer, anyone else see that as a bit of a giant leap?
Not really, worked on the wobblies for a while :p
1 - 9 of 9 Posts
