The high level brake light on my clio is working, but not the 'main' brakelights.
I just checked the bulbs and both filaments appear intact (dark outside) as do the fuses.
The running lights are fine.
Any suggestions gratefully received.
Sometimes the bulb filaments look ok but don't always make good contact. I would change the bulbs 1st and then explore other things.
You'd be surprised at how many people drive around here with JUST the high level brake light working
Hi whilst there is a topic floating around about brake lights can i jump in! My wifes T reg RXE Clio has a third brake light which does not work, but the others do? Anyone know where to start checking? I know its not a legal requirement but the more brake lights the better!
Check the wiring connector - I don't think there is a seperate fuse for it, and I doubt all the bulbs would have blown at the same time (unless the last owner neglected it - I'd check the bulbs anyway)
Thanks for that will have a look this weekend and see what i find. Looks like its going to be nice and sunny so no doubt i will be asked to wash it for her!
By the way do must of us blokes wash our other halfs cars? I believe that if she drives through puddles they should wash them! Anyway what she doing out of the kitchen!!:rofl:
