:confused:i have just bought renault cd/radio & have tried to install it i have the code but there is no code/flashing cursors on the display
there is bleep from speakers when i turn it on & push any button but just the clock & temp is displayed.i have disconnected the negative from battery & reconnected but still no joy.its a 1999 megane.i have also held in the no 6 which i was told might work,
O
I don't know about that model, but I think it could be too new for your car.
The newer units use a different pin out and so even if it works, you won't be able to see the display. So you won't be able to input a code.
thanks,i'll take it back to the car breakers & buy an older version from e-bay although i just put the original radio/cassette in & theres no power to it & no code display.
if you put the old 1 back in and there is no power to that make sure you havent blown a fuse
when i put the cd in there is power getting to it as you can here it whirring when i plug in the loom & beeps when any button pushed.
