Hi all i`m new here 1st post hope someone can help.
I own a Renault megane coupe 1600e sport r reg 1998,i used the car on staurday and everything was fine parked up then didnt use it sunday tried to start it monday and it wouldn`t start,i noticed that the engine management light is not coming on,since then i have had the rac out they said there was no spark and no fuel getting to the engine the fuel pump does`nt even fire up,other than that they had no clue,what a waist of space:devil:.
anyway i`ve done a bit of research since,i found out that it could be that the ecu wasn`t earthed or no power so located the earth wires on the engine cleaned and still no engine managment light all fuses are fine,engine immobiliser is working fine no change to actions everything else works fine except the light it doesn`t even self test when i turn the key,usually comes on for 2 sec then goes out but now there`s nothing,also i have heard there is a relay for the ecu does anyone know where this is located,checked fuses by battery in car and on n/s/f wing all fine,would this actually be a damaged ecu,if anyone could help it would be greatly appreciated because i`m ready to burn it:d
