hi guys when i engage any gear the engine moves sideways (to the right as i look in the bay) then starts to jump around, ive looked at the mounts and apart from moving they dont look damaged, could it be the gearbox?
Hi Bricuda - is the engine running OK if it was off a cylinder it would jerk around a bit. Also where are you standing when viewing:)
Hi Bricuda - if you are getting no drive from the gearbox ot could be faulty clutch broken driveshaft or fault in the gearbox. i would check the driveshafts first as they can be seen from underneath:)
yes both drive shafts are fine, ive taken the end cover off and the top rod can move in and out but the bottom on wont, also clutch bites fine, it feels like the box is jambed
