98 Clio Paris 1.2RL Petrol Manual
You have probably had this problem before but i can't find the thread. My clio won't start from time to time, all the lights come on as usually when i turn the key to the ignition position but when i try to start the engine nought happens.
When it starts it runs fine but when it refuses to do anything it frustrates me:steam: .
Can anyone help?
Yep,Chris is spot on as always.:)
Pay particular attention to the small solenoid wire on the starter.They can corrode causing you fault.If none of the above helps,then suspect the starter it's self.:)
